Ir para o conteúdo principal
  1. Este passo não foi traduzido. Ajude a traduzi-lo
    We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Este passo não foi traduzido. Ajude a traduzi-lo
    Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. Este passo não foi traduzido. Ajude a traduzi-lo
    If you don't have a microwave, follow this step to heat your iOpener in boiling water. Fill a pot or pan with enough water to fully submerge an iOpener.
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. Este passo não foi traduzido. Ajude a traduzi-lo
    If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. Este passo não foi traduzido. Ajude a traduzi-lo
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
  7. Este passo não foi traduzido. Ajude a traduzi-lo
    There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness. Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack. It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
  8. Este passo não foi traduzido. Ajude a traduzi-lo
    Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
  9. Este passo não foi traduzido. Ajude a traduzi-lo
    Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool. Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
  10. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches. Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
  11. Este passo não foi traduzido. Ajude a traduzi-lo
    While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
  12. Este passo não foi traduzido. Ajude a traduzi-lo
    While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad. Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go. The adhesive is very strong, and some serious force may be required. Work carefully.
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
  13. Este passo não foi traduzido. Ajude a traduzi-lo
    It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  14. Este passo não foi traduzido. Ajude a traduzi-lo
    Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering. Re-heat the iOpener, and move it to the top  edge of the iPad.
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
  15. Este passo não foi traduzido. Ajude a traduzi-lo
    The next few steps require extreme caution.
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
  16. Este passo não foi traduzido. Ajude a traduzi-lo
    Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there. Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
  17. Este passo não foi traduzido. Ajude a traduzi-lo
    This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly. Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
  18. Este passo não foi traduzido. Ajude a traduzi-lo
    Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth. Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
  19. Este passo não foi traduzido. Ajude a traduzi-lo
    Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button. If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working. Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  20. Este passo não foi traduzido. Ajude a traduzi-lo
    Continue releasing the adhesive all the way along the bottom edge of the iPad. On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
  21. Este passo não foi traduzido. Ajude a traduzi-lo
    Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
  22. Este passo não foi traduzido. Ajude a traduzi-lo
    Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket. The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad. If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled  too much, reheat it.
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
  23. Este passo não foi traduzido. Ajude a traduzi-lo
    Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner. If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  24. Este passo não foi traduzido. Ajude a traduzi-lo
    Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer. The digitizer cable is located approximately  2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad. The digitizer cable is located approximately  2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
  25. Este passo não foi traduzido. Ajude a traduzi-lo
    Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner. The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
  26. Este passo não foi traduzido. Ajude a traduzi-lo
    Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers. Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
  27. Este passo não foi traduzido. Ajude a traduzi-lo
    Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad. Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
  28. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
    • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
  29. Este passo não foi traduzido. Ajude a traduzi-lo
    Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad. Rotate the LCD along its left edge and lay it down on top of the front panel. Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
    • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
    • Rotate the LCD along its left edge and lay it down on top of the front panel.
    • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
  30. Este passo não foi traduzido. Ajude a traduzi-lo
    Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
    • Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
  31. Este passo não foi traduzido. Ajude a traduzi-lo
    Flip up the retaining flap on the LCD ribbon cable ZIF connector. Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board. You may have to force restart the iPad by holding down the power button and home button for at least ten seconds until you see the Apple logo if the LCD screen doesn't power on after connecting the ZIF connector for the LCD screen when putting everything back together.
    • Flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
    • You may have to force restart the iPad by holding down the power button and home button for at least ten seconds until you see the Apple logo if the LCD screen doesn't power on after connecting the ZIF connector for the LCD screen when putting everything back together.
  32. Este passo não foi traduzido. Ajude a traduzi-lo
    Without touching the front of the LCD, lift the LCD off the front panel.
    • Without touching the front of the LCD, lift the LCD off the front panel.
  33. Este passo não foi traduzido. Ajude a traduzi-lo
    Using the tip of a spudger, peel back the piece of tape that secures the touchscreen ribbon cable to the logic board.
    • Using the tip of a spudger, peel back the piece of tape that secures the touchscreen ribbon cable to the logic board.
  34. Este passo não foi traduzido. Ajude a traduzi-lo
    Flip up the retaining flap on both of the touchscreen ribbon cable ZIF connectors. Flip up the retaining flap on both of the touchscreen ribbon cable ZIF connectors. Flip up the retaining flap on both of the touchscreen ribbon cable ZIF connectors.
    • Flip up the retaining flap on both of the touchscreen ribbon cable ZIF connectors.
  35. Este passo não foi traduzido. Ajude a traduzi-lo
    Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable. Pull the digitizer ribbon cable straight out of its sockets on the logic board.
    • Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable.
    • Pull the digitizer ribbon cable straight out of its sockets on the logic board.
  36. Este passo não foi traduzido. Ajude a traduzi-lo
    Peel back the touchscreen ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case. Peel back the touchscreen ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
    • Peel back the touchscreen ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
  37. Este passo não foi traduzido. Ajude a traduzi-lo
    Using your fingers, pull the touchscreen ribbon cable out of its recess in the aluminum frame.
    • Using your fingers, pull the touchscreen ribbon cable out of its recess in the aluminum frame.
    • Remove the front panel from the iPad.
Linha de Chegada
81 outras pessoas concluíram este guia.
Brett Hartt
Membro desde: 12/04/2010
122.082 Reputação
143 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
139 Membros
17.021 Guias de autoria
5 comentários
It's best when replacing the front panel to power on the iPad once the new panel is connected to test the digitizer before exposing and laying down the glue for the front panel!
Kevin Hulett - Responder
I would recommend that in cases of replacing shattered screens, that you tape the front panel glass with clear packing tape using overlapping strips, before you begin. This helps to ensure that the panel stays intact, and reduces the chances of puncturing the digitizing layer, and damaging the LCD upon removal.
You want to use clear tape so that you are able to see how any of the glass remnants are shifting during removal.
dcorsivo - Responder
Is there an image somewhere that indicates where the new adhesive strips are supposed to go?
byron - Responder
Top tip: check the LCD is in working order before you even take the new parts out of their packaging. I'm going to have to return all mine unfortunately, so glad I checked first.
My screen had spiderweb cracks originating right on part of the edge/frame and it was impossible to slide the picks beyond that point. The only option was to try to lift the "new" side which immediately sent many more cracks across the screen to the other side. At that point there was really no way to get the glass off because both sides where shattered and there was no glass to lift off… First repair that I've ever failed, bummer!
mikemiller73 - Responder
To prevent getting finger prints on the LCD and underside of the touch screen, wear a pair of latex or nitrile gloves.
Andy Robichaud - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 33,042
