Ir para o conteúdo principal
iPad 2 GSM SIM Card Replacement
O que você precisa
  1. iPad 2 GSM SIM Card Replacement, SIM Card: passo 1, imagem 1 %32 iPad 2 GSM SIM Card Replacement, SIM Card: passo 1, imagem 2 %32
    • Use a SIM eject tool or an uncoiled paperclip to eject the SIM card tray.
    My iPad 2 doesn’t have a SIM card slot.
    Nolan Clewell - Responder
  2. iPad 2 GSM SIM Card Replacement: passo 2, imagem 1 %32 iPad 2 GSM SIM Card Replacement: passo 2, imagem 2 %32
    • Pull the SIM tray out of its slot and remove it from the iPad 2.
    • If replacing the SIM card, pop it out of its tray and install the new one.
    What if SIM card is stuck inside a slot?!
    You know - modern SIM-cards are produced in all-in-one format - when you can plug-out normal SIM, micro-SIM and nano-SIM from the same plastic form.
    Dmitry Bond - Responder
Conclusão
19 outras pessoas executaram este guia.
3 comentários
Someone deserves a gold medel for this guide...
thegoldhammer - Responder
My iPad 2 does not have the sim card slot shown above.
patrickpeterson2 - Responder
my iPad 2, labelled as a model A1397, does not appear to have this micro SIM opening. Is there a SIM for GSM and no SIM for CDMA?
rspydell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 78
Duração total: 63,095
