Ir para o conteúdo principal
iPad 2 GSM Logic Board Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPad 2 GSM Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 iPad 2 GSM Logic Board Replacement, Logic Board: passo 1, imagem 2 %32 iPad 2 GSM Logic Board Replacement, Logic Board: passo 1, imagem 3 %32
    • If present, remove the piece of tape covering the end of the dock connector cable.
    • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
    • Peel the dock connector ribbon cable off the rear panel.
  2. iPad 2 GSM Logic Board Replacement: passo 2, imagem 1 %32
    • Place the prying tool beneath the 4 wires on the end of the connector and gently pry the speaker cable connector straight up from its socket on the logic board. Do not pry from the opposite end of the connector as this will break the 4 solder points on the underside of the socket and will require a microsolder repair.
  3. iPad 2 GSM Logic Board Replacement: passo 3, imagem 1 %32 iPad 2 GSM Logic Board Replacement: passo 3, imagem 2 %32 iPad 2 GSM Logic Board Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool to flip up the retainer securing the upper component board cable connector to its socket on the logic board.
    • Pull the connector away from its socket on the logic board.
    • Do not lift the cable upward as you disconnect it.
  4. iPad 2 GSM Logic Board Replacement: passo 4, imagem 1 %32 iPad 2 GSM Logic Board Replacement: passo 4, imagem 2 %32
    • Remove the two 2.1 mm Phillips screws securing the logic board bracket to the rear case near the digitizer cable socket.
    • Remove the logic board bracket from the rear case.
  5. iPad 2 GSM Logic Board Replacement: passo 5, imagem 1 %32
    • Remove the four 2.6 mm Phillips screws securing the logic and communications boards to the rear panel.
  6. iPad 2 GSM Logic Board Replacement: passo 6, imagem 1 %32 iPad 2 GSM Logic Board Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to gently pry the logic board up from the rear case.
    • The logic board is adhered to the rear case; work slowly and uniformly to peel up the glue without damaging the board.
  7. iPad 2 GSM Logic Board Replacement: passo 7, imagem 1 %32
    • Lift the logic board out from the rear case, and rotate it slightly toward the battery.
    • Do not try to completely remove the logic board. There are still three antenna cables attached to it.
Conclusão
Andrew Optimus Goldheart
Membro desde: 10/17/09
509.014 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.631 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 229
