Ir para o conteúdo principal
iPad 2 CDMA Front Panel Adhesive Strips Replacement
O que você precisa
  1. iPad 2 CDMA Front Panel Adhesive Strips Replacement, Home Button: passo 1, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement, Home Button: passo 1, imagem 2 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement, Home Button: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Carefully grasp the home button with a pair of tweezers.
    • Gently lower and place the home button into the round opening located at the bottom of the front panel.
    • The correct orientation of the home button is shown in the third picture. Make sure the back of the home button is face up and the flat portion of the inner home button circle is oriented to the top of the iPad.
    Pergunte ao FixBot
  2. iPad 2 CDMA Front Panel Adhesive Strips Replacement, Front Panel Adhesive Strips: passo 2, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement, Front Panel Adhesive Strips: passo 2, imagem 2 %32
    • The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel.
    • Carefully peel off the first trapezoidal adhesive strip.
    Pergunte ao FixBot
  3. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 3, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 3, imagem 2 %32
    • Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
    • Make sure to line up the profile of the strip with the edge of the mounting bracket.
    • Repeat the procedure for the second trapezoidal adhesive strip.
    Pergunte ao FixBot
  4. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 4, imagem 1 %32
    • Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
    • Lift and peel the brown backing up off the adhesive strip, revealing the clear adhesive strip.
    • Repeat the procedure for the secondary adhesive strip.
    Pergunte ao FixBot
  5. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 5, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 5, imagem 2 %32
    • Gently place the home button mounting bracket on top of the home button.
    • Make sure the home button mounting bracket is lined up with the bottom of the digitizer.
    Pergunte ao FixBot
  6. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 6, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 6, imagem 2 %32
    • In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
    • Do not peel the brown backing off the strips just yet.
    • Place the largest L-shaped adhesive strip on the top left corner of the front panel.
    • Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
    Pergunte ao FixBot
  7. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 7, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 7, imagem 2 %32
    • Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel.
    Pergunte ao FixBot
  8. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 8, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 8, imagem 2 %32
    • Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket.
    Pergunte ao FixBot
  9. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 9, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 9, imagem 2 %32
    • Place the straight adhesive strip on the right side of the front panel.
    • If you've already attached the digitizer cable, you'll have to work around/under it to attach this strip.
    Pergunte ao FixBot
  10. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 10, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 10, imagem 2 %32
    • Place the last L-shaped adhesive strip on the bottom right corner of the front panel.
    Pergunte ao FixBot
  11. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 11, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 11, imagem 2 %32
    • Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame.
    Pergunte ao FixBot
  12. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 12, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 12, imagem 2 %32
    • Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket.
    Pergunte ao FixBot
  13. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 13, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 13, imagem 2 %32
    • Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel.
    Pergunte ao FixBot
  14. iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 14, imagem 1 %32 iPad 2 CDMA Front Panel Adhesive Strips Replacement: passo 14, imagem 2 %32
    • Make sure that each adhesive strip is placed in the correct location and orientation before peeling the backing.
    • Peel the brown backing up off each adhesive strip.
    • Some of the adhesive strips are quite small and may require some patience to peel the backing.
    Pergunte ao FixBot
Conclusão
25 outras pessoas executaram este guia.
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.718 guias
1Comentário do guia
grazie senza di voi non avrei saputo neanche da dove iniziare invece con voi o cambiato il pannello frontale crepato del ipad 2 model 1395 ancora grazie le vostre guide sono perfette
severino1963 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 87
Ao todo: 7,762
