Ir para o conteúdo principal
iON SnapCam 1046 Lite Capture Button Replacement
O que você precisa
  1. iON SnapCam 1046 Lite Capture Button Replacement, Camera Lens and Cover: passo 1, imagem 1 %32 iON SnapCam 1046 Lite Capture Button Replacement, Camera Lens and Cover: passo 1, imagem 2 %32
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Capture Button Replacement: passo 2, imagem 1 %32
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Capture Button Replacement: passo 3, imagem 1 %32
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Capture Button Replacement: passo 4, imagem 1 %32 iON SnapCam 1046 Lite Capture Button Replacement: passo 4, imagem 2 %32 iON SnapCam 1046 Lite Capture Button Replacement: passo 4, imagem 3 %32
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  5. iON SnapCam 1046 Lite Capture Button Replacement, Capture Button: passo 5, imagem 1 %32 iON SnapCam 1046 Lite Capture Button Replacement, Capture Button: passo 5, imagem 2 %32
    • Remove the motherboard by pulling it from the edges as circled.
  6. iON SnapCam 1046 Lite Capture Button Replacement: passo 6, imagem 1 %32
    • Replace capture button with advanced soldering and circuitry (circled in red).
Conclusão
Once the capture button has been replaced, reassemble the iON SnapCam Lite by following these steps in reverse order.
Ahmad Syamil Ali
Membro desde: 11/20/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S22-G4, Bayer Fall 2017 Membro de IUPUI, Team S22-G4, Bayer Fall 2017
IUPUI-BAYER-F17S22G4
Membros da 5
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 138
