Introdução
A basic representation on replacing the lens on the iON SnapCam 1045.
O que você precisa
Detach the magnetic clip from the bottom of the camera.
The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
To get to the motherboard, safely lift the battery to expose an Aluminium plate that shields and holds the motherboard in place.
The plates are held down by four Phillips 0.008 mm screws on all four corners. Use a Phillips head #000 to safely loosen the screws.
The motherboard is in plain sight . The lens assembly is located on the lower left part of the motherboard just to the left of the power button.
To replace the lens assembly, simply flip it up and detach.
