Ir para o conteúdo principal
iON SnapCam 1045 Wearable HD Video Camera Battery
O que você precisa
  1. iON SnapCam 1045 Wearable HD Video Camera Battery, Battery: passo 1, imagem 1 %32
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. iON SnapCam 1045 Wearable HD Video Camera Battery: passo 2, imagem 1 %32
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. iON SnapCam 1045 Wearable HD Video Camera Battery: passo 3, imagem 1 %32
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. iON SnapCam 1045 Wearable HD Video Camera Battery: passo 4, imagem 1 %32 iON SnapCam 1045 Wearable HD Video Camera Battery: passo 4, imagem 2 %32
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
Conclusão
Uma outra pessoa concluiu este guia.
Olakunle
Membro desde: 11/11/17
102 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G3, Wilson Fall 2017 Membro de IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 698
