Ir para o conteúdo principal
iMac Intel 27" Retina 5K Display Adhesive Strip Replacement
O que você precisa
  1. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Determine which adhesives you have: passo 1, imagem 1 %32
    • Before you begin, make sure you have the right adhesive strips:
    • The 2012-2019 iMac adhesive strips have a microphone cutout and are numbered 16, 21, 22, 23, 25, and 26. They can be used on 27" iMacs from 2012-2019.
    • If your strips are numbered 11-16, follow the 2012-2015 iMac adhesive guide instead.
    Is there anything better than these self-adhesive strips?
    They don’t seem as thick as the original adhesive and not as strong. As the adhesive weakens when warm, I’ve had a screen come loose within a few days of use. Luckily the user was in front of it to catch it, else we could have been looking at a very expensive repair.
    Cool_Breeze - Responder
    Hello, in 99% of cases this happens because the residues of the old stripes on the display side have not been completely removed.
    McFix - Responder
    My strips are labelled 14, 15, 16, 21, 22, 23 in a kit for the late 2013 iMac. That matches neither set mentioned here. So I have 14 and 15 instead of 25 and 26. It seems a mix of the two sets described, but since either should work for the 2013 model I should be fine?
    Bernd - Responder
  2. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Stabilize the iMac: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    iMac Intel 27" Cardboard Service Wedge
    Comprar
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iFixit cardboard service wedge.
    • Follow these assembly directions to put the service wedge together.
    • If you are not using an iMac service wedge, be very careful when installing and working behind the display—it can easily fall out and break if the iMac moves unexpectedly.
  3. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Remove the old adhesive: passo 3, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Remove the old adhesive: passo 3, imagem 2 %32
    • Before you install new adhesive strips, remove all of the old adhesive from the perimeter of the rear enclosure.
    • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
    • Peel off the adhesive strips using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
    • After all the old adhesive is removed, carefully clean the surface with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
    • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
    The black border on the back of the screen glass appears to be painted on. When removing the foam adhesive, be careful with tools as it can scratch off the paint and that will show through when all is back together. Fingernails worked best for me; peeling the tape up slowly followed by the alcohol wipe.
    Tom Pentz - Responder
    On mine the glue stuck mostly to the enclosure. It required a lot of elbow grease to get it off.
    Larry - Responder
    Used a little dab of Goo Gone with a micro fiber cloth and a lot of elbow grease on the enclosure to remove the adhesive. As far as the glass side, mine was fairly clean so I just used some 70 % alcohol and was careful. Then went back over all areas with 70 % alcohol again. Was able to clean everything thoroughly. It’s tough but worth it for good adhesion. Thanks Darren S.
    Darren Stewart - Responder
    My 27" iMac was damaged in shipping and I had to replace the display. When trying to replace the display, I found that the case was bent on the top, just barely visible. Makes sense as the top right corner of the display was totally smashed... Check your display fit and alignment BEFORE placing the adhesive strips. This way you can work on straightening the frame without worrying about damaging the adhesive strips.
    The case is actually soft, in that it is easily bent. Work only when relaxed and not stressed out! I used my body weight and a small piece of wood as a fulcrum to accomplish the (un)bends. If you place it on a totally flat surface you can see where it's touching and where it's high, so you know where to bent it. I had to use some pliers to get the last bit straight. I used multiple (4 - 6) layers of cardboard under the pliers to prevent scratching the aluminium. Go gently, slowly, checking for alignment / flatness many times, rather than doing too much and having to bent it back again.
    VikingShips - Responder
  4. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Lay out the adhesive strips: passo 4, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Lay out the adhesive strips: passo 4, imagem 2 %32
    • Lay out the adhesives strips beforehand so you won't accidentally install a strip in the wrong place:
    • Strip 22 on the top left
    • Strip 23 on the top right
    • Strip 21 on the right vertical
    • Strip 25 on the bottom right, dark side facing up.
    • Double check to make sure this strip has the necessary cutout for the microphone.
    • Strip 26 on the bottom left, dark side facing up
    • Strip 16 on the left vertical
  5. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Install the right side adhesive: passo 5, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Install the right side adhesive: passo 5, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Install the right side adhesive: passo 5, imagem 3 %32
    • Start with strip 21, which goes on the right vertical edge of the iMac frame.
    • Before you peel off any backing, line the adhesive strip up along the frame of the iMac to get an idea of where it goes.
    • Peel the short piece of backing off the back of the strip.
  6. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 6, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 6, imagem 2 %32
    • Insert the tip of a spudger into the hole at the end of the strip where you just removed one layer of backing. Insert the spudger from the side that still has a layer of white backing on it.
  7. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 7, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 7, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 7, imagem 3 %32
    • With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
    • Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pull down against the spudger to ensure the strip is taut, and stick it onto the frame.
  8. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 8, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 8, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 8, imagem 3 %32
    • Once you're satisfied that the top half of the adhesive strip is neatly aligned, peel longer blue piece of backing out from behind the strip.
    • If the top half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  9. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 9, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 9, imagem 2 %32
    • Align the lower portion of the strip with the right edge of the frame, and stick it down.
  10. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 10, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 10, imagem 2 %32
    • Use your finger to smooth out the strip. Make sure it is neatly aligned with the right side of the frame and that it sits flat.
    • Do not peel off the front adhesive backing yet.
  11. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Install the top and left adhesives: passo 11, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Install the top and left adhesives: passo 11, imagem 2 %32
    • Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
    • Strip 16 on the vertical left
    • These three strips have a hole at each end—always use the smaller hole for alignment for more precise placement.
    • On the iMac Intel 27" Retina 5K Display, the top-right strip's blue tabs will not line up with the top antenna in the same way as the non-5K model. This is perfectly acceptable and won't impact the performance of the strips or antenna.
    2017 27”, lining up the top strips with the smaller outside holes, the tape holes at the other end did not line up with the larger holes in the case, near the camera.
    ebay - Responder
    For the late 2012 27” iMac, strip 23 didn't line up correctly with the antenna. the antenna adhesive was a cm off from where it should have been. No biggie though.
    Daniel - Responder
    I can confirm above comment - EMC 2546 Late 2012 27" iMac, strip 23 antenna does not align with adhesive.
    Michael - Responder
  12. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Install the bottom adhesives: passo 12, imagem 1 %32
    • The next few steps will show you how to install the bottom right adhesive strip (strip 25), which includes a notch that must be aligned with the microphone.
    • Read through this step and the next four steps before you attempt the procedure.
    • Grasp the red pull tab on strip 25 and pull to separate about 2 inches (5 cm) of white backing from the strip.
    These steps instruct you to install the lower strips to the iMac frame first, as that is what Apple instructs their techs to do. If you have an iMac without a microphone hole, you can choose to install the lower strips onto the display first. Peel the blue tab instead of the red to expose the adhesive. Carefully place the adhesive along the bottom edge of the display. The L-bend on the adhesive should match the display contours.
    Arthur Shi - Responder
    My EMC No. 2546 did not have a microphone hole, so I was confused at first. A different instructional video (https://vimeo.com/139364064) recommends placing the strips on the display instead. I installed the strips on the frame, but I reckon installation on the display glass might have been a better option, at least with no microphone hole to contend with.
    Lennart Saaf - Responder
    Yep, no microphone hole on the late 2012 27” iMac. I followed the video but I don’t think it made anything easier.
    Maybe my mistake was putting the screen back on when the frame was lying down. I was left with a mm gap on one side due to misalignment. Stand up the mac so the screen can sit on the lip and be aligned properly.
    Daniel -
    Je pense qu’il est possible de coller les adhésifs inférieurs légèrement plus haut que sur l’image, pour dégager 2mm afin de permettre à l’écran à l’horizontale de glisser latéralement pour faciliter l’alignement lors du remontage.
    stbrille - Responder
  13. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 13, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 13, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 13, imagem 3 %32
    • Fold the loose white backing to a right angle and pinch the crease with your fingers.
    • This exposes 2 inches of adhesive while folding the red tab out of the way.
    I had difficulty here. The red tab wanted to pull off from the white backing.
    ebay - Responder
    It's not the red tab. It's the bond between the white backing and the adhesive that's causing the problem. When I tried to peel the white backing off, it takes the adhesive along with it. I had to detach it with my finger nail, already risking a weaker bond between the screen and the adhesive. I thought the problem was only around the edge of the strip (where I had to pull the red tab), but the whole strip was pulling the adhesive off the clear backing as I was aligning it with the iMac. This is the second time this has happened with these strips. And now I'm concerned, since the adhesive is now slightly compressed and there's a little air gap in the middle now...
    adrianfpommier -
  14. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 14, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 14, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 14, imagem 3 %32
    • The microphone hole is the center hole flanked by two larger holes.
    • Align the adhesive strip to the bottom edge by positioning the microphone notch over the microphone hole.
    • If your iMac does not have a microphone hole, align the right end of the strip such that the L-bend sits next to the right vertical adhesive. The L-bend should not overlap the right vertical adhesive.
    • The adhesive tears easily. Be careful not to pull on the strip with too much force.
    • Once you have aligned the strip, carefully set the left exposed edge onto the iMac to secure the alignment.
    Can anyone confirm that the mic is the middle small hole as the photo in step 14 appears to show a larger hole? I ask as I don’t have the mic kit and will have to cut the kit to suit my late 2015 iMac 27 retina. Thanks.
    Amuseme - Responder
    Good catch!! Yes, the mic hole is the small center hole. The step image is showing the wrong hole. I’ll upload the correct photo shortly.
    Arthur Shi -
    i have a late 2015 iMac 27” 5K (iMac 17,1) and I do not have a microphone along the bottom. I am confused because other people do?
    R L - Responder
    The 2017 iMacs (both 21.5 and 27" models) were the first to have the microphone at the bottom. Previous models had it at the top center with the camera.
    Mike Rosenberg -
  15. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 15, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 15, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 15, imagem 3 %32
    • Peel away the white backing behind the strip to expose the remaining adhesive.
  16. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 16, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 16, imagem 2 %32
    • Run your finger from left to right along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
  17. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 17, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 17, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 17, imagem 3 %32
    • Repeat the previous steps for the bottom left adhesive strip (strip 26), aligning and placing it along the bottom left edge of the iMac.
    • The strip should be positioned such that the L-bend sits next to the left vertical adhesive. The L-bend should not overlap the left vertical adhesive.
    • Once you've applied all the adhesive strips, the iMac should look as shown in the second photo.
    This strip is adjacent to the power supply of the iMac. Take care not to touch any part of the power supply module during this step.
    Zachary Hill - Responder
    At this point, before proceeding, I would make sure the the power supply is fully de energized(no power cord) by holding down the power button for 30 seconds!
    Macrepair SF - Responder
  18. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Replace the display: passo 18, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Replace the display: passo 18, imagem 2 %32
    • Gently set the display in place over the iMac and align it carefully.
  19. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 19, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 19, imagem 2 %32
    • Use painter's tape or masking tape to temporarily secure the bottom edge of the display to the iMac's enclosure.
    • The tape preserves the display's alignment, and allows you to safely swing the top edge of the display open to access the display cables.
    I used 2” painter’s tape to hold the display in place, but did it a little differently. With the wedge holding the iMac at an angle, I laid the display in place and felt on the sides to make sure it was centered. Then I put small strips (4-5” long) all along the sides and top, wrapping the tape around to the back of the display to hold it in place. Then tested my repair to make sure everything worked.
    I had seen some comments about problems with the strips holding in place over time, so I didn’t actually install them. Instead, I’ve left the painter’s tape on mine. I’m a week or more in, and so far there’s no sign of failure to hold. I’m going to leave it this way until I decide whether or not to replace the blade and hard drive with an SSD. I find I don’t even notice the painter’s tape as I’m using my iMac.
    paul - Responder
    Paul- If you haven’t made the move to SSD yet, i suggest you replace the SATA 3.5” HDD with a 2.5” SSD, and leave the blade SSD already installed in place. You can create a new Fusion Drive with the SATA SSD & stock blade SSD. This allows you to still take advantage of the blade SSD for extra RAM.
    I just did this myself on my Late 2015 iMac 5K with the 2TB Fusion Drive. I swapped the dinosaur HDD for a 4TB Samsung 870 QVO 2.5” SATA SSD and my computer feels like new! better than new!
    I don’t recommend replacing the blade SSD because it’s a lot more complicated and you run a real risk of damaging the logic board.
    R L -
    @R L I'm 99% certain that it is not possible to fuse two SSD drives (and certainly not advised). i.e. your 2.5" SATA SSD and your stock blade SSD. I'm about to replace the failing 3TB HDD in my Late-2013 iMac 27 (stock 128gb blade SSD). My plan, assuming the blade drive even mounts, is to format it and let it mount as a separate volume. It's too small to really be of any use and my understanding is the disparate speeds may actually reduce performance overall.
    Kupe - Responder
    I have fused the stock ssd drive with a samsung evo ssd drive for years with no problems in my 2012 iMac The downside is that to do so you have to boot from a recovery disk and do pretty complicated stuff with terminal to fuse both ssd drives. Once that's done you cannot touch your fusion drive with disk utility (mac will not reboot and you will have to erase both disk and start over). The easy option is just leave both drives separated, they work just like any standard ssd drive.
    David C. - Responder
    It seems to me that some emphasis could be added to this step. I had successfully upgraded my HDD to SDD, and I had confirmed the success of the upgrade by booting my iMac 5G 27 2017 to the Apple prompt. In this step 19, I did not use a sufficient, nor a strong enough masking tape to hold my monitor when I was attempting to remove the backing from the bottom adhesive strips in Step 23. When the tape let go, the monitor screen dropped, and unfortunately I still had the power and data cables connected. In the process the data cable and the power cable receptacle were damaged. I hope to recover by purchasing a new data cable. the power receptacle is still usable, perhaps with an adhesive tape piece over the connection. I found this procedure difficult.
    NTAbbott - Responder
  20. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Test your repair: passo 20, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Test your repair: passo 20, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Test your repair: passo 20, imagem 3 %32
    • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
    • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to step 22.
    • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
    • Flip the display data connector lock down onto the socket.
    • Insert the display power connector into its socket on the logic board.
    After I completed this repair I noticed that the fan was spinning all the time. What is going on?
    Diane Radke - Responder
    If the fan is going constantly the thermal (temperature) sensor is likely not attached to the hard drive. It should be okay to run it like this - but it’s loud… Better to have the thermal sensor attached and configured. I bought my kit from iFixit and the sensor was wrapped in some of the paper packaging - took me a few minutes to find it.
    Greg Postma - Responder
    I used my foam support wedge to hold open the glass side from the enclosure side. I placed in in the center to even out the weight. I used the longer areas of the wedge so more was in contact with the two parts. This freed up my hands to plug in both power and data cables. *Just be careful
    You can also use a sw version instead of a hw thermal sensor. I found on my 27 inch iMac 2019, that the hw sensor didn’t really work for me. In fact, some of the ssd cases used in the hard drive bay are made of plastic. I found for me using Mac Fan Control by Crystal Ideal a good alternative. You can use the free version, or pay for the pro version for about 15.00 dollars to have better control of your fan speed. Of course, your mileage may vary.
    George Martinez - Responder
  21. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 21, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 21, imagem 2 %32
    • Set the display back on the iMac's rear enclosure.
    • At this time, plug in your iMac, power it on, and test your repair before sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
    • When you are finished, shut the iMac down and unplug the power cord before you continue.
  22. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Seal the iMac: passo 22, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Seal the iMac: passo 22, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement, Seal the iMac: passo 22, imagem 3 %32
    • Verify that your iMac is turned off and unplugged from power before you continue.
    • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
    • Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
    Here's a sure fire way to replace the LCD onto the frame. It involves using painters tape, a foam wedge and 12" Surgical Hemostat Forceps clamps. iMac is upright on a low table so I can look down into it, painters tape applied, Foam wedge keeps it at an upward tilting angle. Headlamp recommended. LCD and power display connectors have been re-attached. Carefully open the LCD from the frame, keep in mind that the 2 cables give you about 2" of space to "look down" and with your 12" locking forceps grab and lock onto the blue tabs, getting a good, firm bite and then pull upwards to detach from the bottom adhesive strips. There will be 2 of them. The pull tab may detach but not difficult to find the transparent thread to continue the pulling. When both sides have films removed, let the display rest back on the frame and plug it in. If boot screen you can then carefully again separate the LCD slightly to then easily pull off the rest of the strips. Reseal and I use 6 pressure clamps on all sides to cure.
  23. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 23, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 23, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 23, imagem 3 %32
    • Reconnect the display power and data cables for the final time.
    • Remember to secure the metal retaining bracket on the display data cable.
    The display I bought had some pink protective plastic film covering the camera portion of glass on the back of the display. Be sure to remove this before finally seating the display in place! Not doing so would result in improper focusing and a pink tinted picture all the time.
    amazing now it won't turn on anymore. I see as green LED but that's it.
    Kerim Incedayi - Responder
  24. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 24, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 24, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 24, imagem 3 %32
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
    • Steady the display with one hand as you remove the protective film in the following steps, or rest it lightly against the iMac's enclosure.
  25. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 25, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 25, imagem 2 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 25, imagem 3 %32
    • Remove one side of the protective film from the top left strip by pulling its tab straight up.
  26. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 26, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 26, imagem 2 %32
    • Remove the other side of the protective film from the top left strip.
  27. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 27, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 27, imagem 2 %32
    • Repeat the previous steps to remove the protective films from all the remaining adhesive strips.
    When pulling the adhesive strips off I had one snap in half right (just the white part revealing the adhesive) one my top right corner. I panicked because there was not adhesive there so I pulled a quick maneuver. I slipped in one of the guitar pick type triangles near the gap quickly before the adhesive has set in and was then able to slip my bent nose tweezers in and grab the white tape and peal the remaining. Whew! It worked. *Just be careful
  28. iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 28, imagem 1 %32 iMac Intel 27" Retina 5K Display Adhesive Strip Replacement: passo 28, imagem 2 %32
    • To ensure a strong bond, carefully tip the iMac flat on its back (with the screen facing straight up) and press carefully but firmly around all four edges of the display.
    • Remove the tape securing the display to the rear enclosure.
    • Check the display after 24 hours to make sure that it is not loose on the iMac.
    Before lowering the glass display, I would recommend removing the tape from the edges, in order to check that the glass is seated flush against the bottom shelf of the frame. In my case, the glass got slightly out of alignment with all the lifting and lowering of the display, and I ended up with one corner being about 1 mm above the frame ledge. Not a huge error, but regrettable, as once you start to lower the display with all adhesive exposed, there is no turning back!
    A big +1 to this. I had the same issue but was able to adjust the monitor before it was fully set. Hopefully the guide can be updated with this suggestion!
    I also did 1 more power on check after removing the screen after pulling the bottom strips covers off.
    Don Rhodes -
    Has anyone had the display fall out after a few days of use when the machine warms up and the adhesive softens?
    How do we prevent that from happening?
    Is it just my imagination or are the replacement adhesive strips thinner than the Apple originals? After cutting the original adhesive we are left with a thin layer on the frame AND a thin layer on the back of the front glass. To me it feels like the replacement tape is only as thick as one of these layers, so there’s less flex to take up any minor variations in level and ultimately a weaker join.
    I also have no idea if the replacement adhesive retains its grab strength once the machine warms up in use.
    I'm an (unauthorized) Apple computer tech and have replaced over 24 displays on 21.5 and 27" iMacs. The only time I had a display fall off was when I tried using GooGone to remove the adhesive residue. It leaves a greasy residue that is hard to remove and will prevent proper adhesion of the replacement strips. My customer found that her 27" display had fallen off TWICE (both times it miraculously ended up on their office chair with no damage). I now use 91% IPA and the flat edge of a new spudger tool to remove residue. Never had a problem since.
    I've used several different makes of strips purchased via amazon and they all work fine.
    Corey Matsumoto -
    I have the same problem. I followed the instructions exactly, after gluing the display I let the iMac lie on its back for 24 hours.
    Then I tilted the iMac forward and after 2 days the display started to peel off.
    What needs to be done so that the display does not come off? Ambient temperature? Or is it necessary to heat the display somehow after gluing the display?
    Ondrej -
    Corey, could I ask you a question? Have you successfully removed a display after it has been attached using the aftermarket adhesive strips? I didn't have a problem removing the original display adhesive, but when I decided to reopen my iMac to upgrade the SSD, I had a very difficult time, which ended up breaking the screen...Thanks very much
    S. Baxter - Responder
Linha de Chegada
186 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.762 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
24 comentários
This guide works great. Replaced a 2015 IMAC 27" screen without any difficulty especially since I purchased the Ifixit tape kit and removal tools. Thanks guys and gals. Couldn't do it without you.
gordywat - Responder
will this work on late 2015 27"5k iMac
ffjones54 - Responder
Hello, I got a Late 2015 iMac 5K, are the stripes the same?
filmore - Responder
Yes this adhesive strip replacement kit works for the Late 2015 Retina 5K iMac. As mentioned in step 8, the tabs for strip 12 won't line up exactly the same as shown in the guide but it does not matter. It still works and will not interfere with that antenna.
smudge - Responder
Does this work with iMac 27 2017?
macdeutsche - Responder
Used these guides to replace the cpu and ssd’s in my 2015 iMac 27”. Super easy! And yes with a late 2015 model, the cpu is replaceable with a regular Skylake cpu. I bought a 3.2 i5 model and replaced with a 6700K ! And yes these also take 64GB of DDR3. For the PCIE SSD you can get an adapter off of ebay…look for m.2 to iMac adapter…since they’re cheap I recommend getting like 2-3 and figuring out which one works best with your m.2 ssd. So yeah, you can get a 1TB m.2 AND a 1TB 2.5” ssd in this and have a nice little box for peanuts.
Michael Stram - Responder
Friends! This manual and accessories are compatible with the iMac 27 5K 2017?
Anton Gudzuman - Responder
Hi,
I done all of the above on my 2017 27inch iMac and now my microphone won’t work, when I tap the enclosure it reacts but it doesn’t hear my voice commands. Maybe the adhesive tape got stuck on the microphone somehow. where is the microphone located exactly? Help please……
Best regards, Henk
Henk - Responder
I have the same problem. Were you able to fix it?
Andrew Blackman -
I know this is an old question, but I wanted to post a followup so hopefully, no one else makes this mistake. The microphone is located on the lower edge. Here’s the thread that covers this better. Microphone very muffled after sealing up iMac
veenenen -
ottimo complimenti per i dettagli
guida superlativa e precisa grazie del vostro aiuto
gennariello1966@gmail.com - Responder
I did it! Be very careful when you place the tape at the bottom of the screen. The screen can fall off! Also important to keep the imac standing and not laying on it’s back because it will make it hard to remove the bottom adhesives.
Jonathan Meson - Responder
After following to the letter, the screen came off and went back on just fine. 5 days later (while setting in a cool environment) the screen just came unstuck and fell out sometime during the night, Of course it tore the two cables badly in addition to the antenna wires that must have gotten in the way somehow. Took most all day, but was able to the wifi and bluetooth wires back in place and the power cable (4 connector) plug back in. The hardest part was the ribbon cable. With high magnification hood on, was finally able to get it back in it’s socket. Had to tape it down to the rest of the board so it would stay. Used new sealant strips, then CLAMPED with spring clamps (around 12 of um) then laid it flat, screen up, then put it near a baseboard heater for two hours. Temp gun was around 100* all around it. Hopefully that won’t happen again!!
avflyguy - Responder
Excellent write up. Also, the detailed photos were super helpful in seeing the alignment.
The only hiccup I had was trying to remove the final tabs from strip 15 and 14 while the glass was blue taped down. I had to lift the weight of the glass panel off of the tab strips before they came off. Aside from that, a very smooth install, and very quality product. Thanks!
Jonathan Daiello - Responder
Excellent guide. Many thanks.
jhlincoln - Responder
Make sure you totally clean both surfaces. The back of the display can be a real pain. I know someone who told me he replaced the PCI SSD and it all went smooth (same thing I did plus a SATA SSD and new thermal paste) but a few weeks later to his HORROR the 5k display was smashed on his office floor. Make sure to really clean and press on all sides. Keeping some painters tape on the top corners wouldn’t hurt either for a few weeks to make sure it seats well.
Brian Peixinho - Responder
Thank you! Just completed this after an SSD upgrade to my 2015 iMac. Much appreciated Sam!
Kaiser Soze - Responder
would be REALLY nice to have this linked on every single repair page. there was NO MENTION of replacing the adhesive strips at the end of the hard drive replacement guide, and i am now staring at a smashed LCD display that will set me back $600 to replace. very frustrating as I usually love ifixit guides. please consider adding a heavily red-flagged link to this guide and information to every guide that requires removing the display.
Coleman Howard - Responder
This was a super useful guide that formed the closing stage of repairing my old iMac 27” (late 2012). I replaced the power supply and upgraded to an SSD. Thank you so much for taking the time to prepare and improve these guides. They are invaluable and enabling.
Nickie Daniel - Responder
very good - thank you
manxman - Responder
Se me acaba de despegar a las 4 semanas de haberlo utilizado.
Miquel Vera Pedrosa - Responder
Works it in an iMac18,3?
javier - Responder
These instructions add a couple of steps that a well-known Mac accessory vendor's instructional video lacks: taping the screen closed to allow functional testing before you seal the adhesive, the upright positioning using the wedge, that makes it easier to set the bottom edge of the screen fully against the frame, and cleaning the backside of the camera opening before you close it up. All of these are valuable refinements.
Bill S - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 136
Últimos 30 dias: 456
Duração total: 104,163
