Ir para o conteúdo principal
iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement
O que você precisa
  1. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Stabilize the iMac: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    iMac Intel 27" Cardboard Service Wedge
    Comprar
    • Follow these assembly directions to put the service wedge together.
    • Insert the service wedge between the back of the display and the stand.
    • If you are not using a service wedge, the iMac can shift unexpectedly during the repair. You can complete the repair without it, but the procedure will be easier with an iFixit cardboard service wedge.
  2. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Remove the old adhesive: passo 2, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Remove the old adhesive: passo 2, imagem 2 %32
    Comprar
    • Before you install new adhesive strips, remove all of the old adhesive from the perimeter of the rear enclosure.
    • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
    • Peel off the adhesive strips using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
    • After all the old adhesive is removed, carefully clean the surface with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
    • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
  3. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Lay out the adhesive strips: passo 3, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Lay out the adhesive strips: passo 3, imagem 2 %32
    • Lay out the adhesive strips to ensure you install them in the correct place:
    • Strip 22 on the top left
    • Strip 23 on the top right
    • Strip 21 on the right vertical
    • Strip 25 on the bottom right, dark side facing up—double check to make sure this strip has the necessary cutout for the microphone
    • Strip 26 on the bottom left, dark side facing up
    • Strip 16 on the left vertical
  4. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Install the right side adhesive: passo 4, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Install the right side adhesive: passo 4, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Install the right side adhesive: passo 4, imagem 3 %32
    • Start with strip 21, which goes on the right vertical edge of the iMac frame.
    • Before you peel off any backing, line the adhesive strip up along the frame of the iMac to get an idea of where it goes.
    • Peel the short piece of backing off the back of the strip.
  5. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 5, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 5, imagem 2 %32
    • Insert the tip of a spudger into the hole at the end of the strip where you just removed one layer of backing. Insert the spudger from the side that still has a layer of white backing on it.
  6. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 6, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 6, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 6, imagem 3 %32
    • With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
    • Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pull down against the spudger to ensure the strip is taut, and stick it onto the frame.
  7. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 7, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 7, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 7, imagem 3 %32
    • Once you're satisfied that the top half of the adhesive strip is neatly aligned, peel the longer blue piece of backing out from behind the strip.
    • If the top half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  8. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 8, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 8, imagem 2 %32
    • Align the lower portion of the strip with the right edge of the frame, and stick it down.
  9. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 9, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 9, imagem 2 %32
    • Use your finger to smooth out the strip. Make sure it is neatly aligned with the right side of the frame and that it sits flat.
    • Do not peel off the front adhesive backing yet.
  10. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Install the top and left adhesives: passo 10, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Install the top and left adhesives: passo 10, imagem 2 %32
    • Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
    • Strip 16 on the vertical left
    • These three strips have a hole at each end—always use the smaller hole for alignment for more precise placement.
    • On the iMac Intel 27" Retina 5K Display, the top-right strip's blue tabs will not line up with the top antenna in the same way as the non-5K model. This is perfectly acceptable and won't impact the performance of the strips or antenna.
  11. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Install the bottom adhesives: passo 11, imagem 1 %32
    • The next few steps will show you how to modify and install the bottom right adhesive strip (strip 25), which includes a notch that must be aligned with the left microphone and a notch that you must cut to accommodate the right microphone.
    • The microphone is a small hole located between two larger holes.
  12. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 12, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 12, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 12, imagem 3 %32
    • Place adhesive strip 25 on your work surface with the white side facing up and the opening of the microphone notch facing away from you.
    • Measuring from the center of the microphone notch, make two marks on the adhesive strip as guides for where to cut:
    • Make the first mark 13/16 inch (23 mm) right of the notch
    • Make the second mark 1 & 5/16 inch (29 mm) right of the notch
    • Rotate the adhesive strip so that the notch is now facing toward you.
    • Measuring from the bottom edge of the strip, make a third mark in between the first two 5/32 inch (4 mm) up from the bottom edge.
    • This cut will be very close to the top edge of the adhesive strip, but it's important that you leave material over top of the adhesive strip for proper sound isolation. When in doubt, remove less material than you think you need to. If the adhesive still covers the microphone you can always make the notch bigger.
  13. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 13, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 13, imagem 2 %32
    • Very carefully cut along the marks you made with a pair of scissors or a razor blade.
    • After cutting, your microphone notch should look like the one in the second photo.
    • Before removing the backing, place your adhesive strip on the iMac and make sure the notches line up with the microphones.
  14. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 14, imagem 1 %32
    • Grasp the red pull tab on strip 25 and pull to separate about 2 inches (5 cm) of white backing from the strip.
  15. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 15, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 15, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 15, imagem 3 %32
    • Fold the loose white backing to a right angle and pinch the crease with your fingers.
    • This exposes 2 inches of adhesive while folding the red tab out of the way.
  16. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 16, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 16, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 16, imagem 3 %32
    • The microphone hole is the center hole flanked by two larger holes.
    • Align the adhesive strip to the bottom edge by positioning the microphone notch over the microphone hole.
    • If your iMac does not have a microphone hole, align the right end of the strip such that the L-bend sits next to the right vertical adhesive. The L-bend should not overlap the right vertical adhesive.
    • The adhesive tears easily. Be careful not to pull on the strip with too much force.
    • Once you have aligned the strip, carefully set the left exposed edge onto the iMac to secure the alignment.
  17. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 17, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 17, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 17, imagem 3 %32
    • Peel away the white backing behind the strip to expose the remaining adhesive.
  18. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 18, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 18, imagem 2 %32
    • Run your finger from left to right along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
  19. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 19, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 19, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 19, imagem 3 %32
    • Repeat the previous steps for the bottom left adhesive strip (strip 26), aligning and placing it along the bottom left edge of the iMac.
    • The strip should be positioned such that the L-bend sits next to the left vertical adhesive. The L-bend should not overlap the left vertical adhesive.
    • Once you've applied all the adhesive strips, the iMac should look as shown in the second photo.
  20. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Replace the display: passo 20, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Replace the display: passo 20, imagem 2 %32
    • Gently set the display in place over the iMac and align it carefully.
  21. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 21, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 21, imagem 2 %32
    • Use painter's tape or masking tape to temporarily secure the bottom edge of the display to the iMac's enclosure.
    • The tape preserves the display's alignment, and allows you to safely swing the top edge of the display open to access the display cables.
  22. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Test your repair: passo 22, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Test your repair: passo 22, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Test your repair: passo 22, imagem 3 %32
    • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
    • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
    • Flip the display data connector lock down onto the socket.
    • Insert the display power connector into its socket on the logic board.
  23. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 23, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 23, imagem 2 %32
    • Set the display back on the iMac's rear enclosure.
    • Plug in your iMac, power it on, and test your repair before sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
    • When you are finished, shut the iMac down and unplug the power cord before you continue.
  24. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Seal the iMac: passo 24, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Seal the iMac: passo 24, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement, Seal the iMac: passo 24, imagem 3 %32
    • Verify that your iMac is turned off and unplugged from power before you continue.
    • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
    • Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
  25. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 25, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 25, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 25, imagem 3 %32
    • Reconnect the display power and data cables for the final time.
    • Remember to secure the metal retaining bracket on the display data cable.
  26. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 26, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 26, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 26, imagem 3 %32
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
    • Steady the display with one hand as you remove the protective film in the following steps, or rest it lightly against the iMac's enclosure.
  27. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 27, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 27, imagem 2 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 27, imagem 3 %32
    • Remove one side of the protective film from the top left strip by pulling its tab straight up.
  28. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 28, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 28, imagem 2 %32
    • Remove the other side of the protective film from the top left strip.
  29. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 29, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 29, imagem 2 %32
    • Repeat the previous steps to remove the protective films from all the remaining adhesive strips.
  30. iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 30, imagem 1 %32 iMac Intel 27" Retina 5K Display 2020 Display Adhesive Replacement: passo 30, imagem 2 %32
    • To ensure a strong bond, carefully tip the iMac flat on its back (with the screen facing straight up) and press carefully but firmly around all four edges of the display.
    • Remove the tape securing the display to the rear enclosure.
    • Check the display after 24 hours to make sure that it is not loose on the iMac.
Conclusão
5 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
75.456 Reputação
Autoria de 288 guias
2 comentários
I would love to understand how this “microphone” works. After cutting out adhesive space, we glue the display directly on top and the sound somehow travels thru the glass to the microphone?
MyTechGuy - Responder
Merci pour toutes ces précieuses infos.
Ali - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 41
Últimos 30 dias: 196
Duração total: 4,900
