Introdução
Issues with Photobooth and FaceTime? Might be time to replace your iSight camera.
Ferramentas
Peças
Nenhum componente especificado.
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Flip down the metal retaining bracket on the iSight camera cable.
Remove two 4.3 mm T5 screws securing the iSight camera board to the top of the rear case.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
2 outras pessoas concluíram este guia.
