Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Peças
Nenhum componente especificado.
  1. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
    • Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
  2. Peel the black tape connecting the fan to the exhaust duct back slightly. Leave the tape in place on the exhaust duct—you only need to expose the joint to free the fan.
    • Peel the black tape connecting the fan to the exhaust duct back slightly.
    • Leave the tape in place on the exhaust duct—you only need to expose the joint to free the fan.
  3. Remove three 12.4 mm T10 screws securing the fan to the rear case.
    • Remove three 12.4 mm T10 screws securing the fan to the rear case.
  4. Remove the fan from the iMac. Remove the fan from the iMac.
    • Remove the fan from the iMac.
Conclusão
Andrew Optimus Goldheart
Membro desde: 17/10/2009
467.463 Reputação
410 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
133 Membros
14.619 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 203
