Ir para o conteúdo principal
iMac Intel 27" EMC 2429 Access Door Replacement
O que você precisa
  1. iMac Intel 27" EMC 2429 Access Door Replacement, Access Door: passo 1, imagem 1 %32 iMac Intel 27" EMC 2429 Access Door Replacement, Access Door: passo 1, imagem 2 %32
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
    I am going to put a very important comment here. Before you start this process listen to the fans on your iMac do any of them sound obviously loud (think about how quiet your iMac used to sound as a reference) If you notice one or more of them sounding substantially loud compared to the others consider locating a replacement fan prior starting this process. After all if you are already “in the neighborhood” it is a shame to do all this work only to have to disassemble your imac a couple weeks later because you realize the fan is failing. I speak from my own personal learning experience of having to disassembly my iMac 3 weeks later because the HDD was failing and apparently the moving the fan around was just enough to push it to start really under performing.
    Wizbang FL - Responder
    I’m not sure why it is necessary to remove the RAM. As far as I can tell, it can remain in place during this procedure.
    gordonhamachi - Responder
Conclusão
24 outras pessoas executaram este guia.
Phillip Takahashi
Membro desde: 08/22/11
86.704 Reputação
Autoria de 87 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 54
Duração total: 23,255
