Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
A 27" iMac is a great thing. A 27" iMac with a broken display is a great broken thing. Don't let a broken LCD get in the way of your iMac being awesome. Use this guide to help you replace the display in the 2010 27" iMac.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
28 outras pessoas executaram este guia.
6 comentários
Hard to learn, easy to master. There are a lot of trap cables that are not very long. For best results, I like to use cardboard hard drive boxes to prop up my LCD display to a 30° angle so I can reconnect cables with both my hands.
Does anyone know if the display from a 2011 27" iMac is compatible with a 2010 27" iMac? The 2011 in my office died, but the 2010 still works fine, albeit with color trouble due to a malfunctioning display.
They are not. Sorry.
Al
I can disassemble the LCD backlight to clean the dust that does a bad ghost, some of you have already done it
Hello ! Do you have, any idea where I can buy the display replacement?
