Introdução
Use this guide to replace a faulty camera board.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Remove the two T10 Torx screws securing the camera board to the outer case.
3 outras pessoas executaram este guia.
Um comentário
Tedious as heck, but better than plopping a USB camera on the top or on the side. :-)
