Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replace a faulty AirPort card to regain wireless internet connectivity.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Use the flat end of a spudger to pry both AirPort antenna cable connectors up off the AirPort card.
9 outras pessoas executaram este guia.
3 comentários
If you can replace the airport card, try to replace the daughterboard that it resides in while you are at it.
Can you replace the airport card so as to support wifi 802.11ac and bluetooth 4.0? Is this card available anywhere ??
Hi Brett,
At Step 5. there was 2 separate cable (Black/Gray) connector . The board connector has little damage and cable connector can insert top or bottom either way. Would you please tell me which is Black or Gray wire next to “CN2” print on board. I am very appreciate your help.
Poor knowledge Mac Fan in Japan
