Ir para o conteúdo principal
iMac Intel 27" EMC 2390 Access Door Replacement
O que você precisa
  1. iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: passo 1, imagem 1 %32 iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: passo 1, imagem 2 %32
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
Conclusão
12 outras pessoas executaram este guia.
Um comentário
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
Kevin McCartney - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 9,090
