Introdução
Use this guide to replace a faulty SD Board.
Ferramentas
Peças
Nenhum componente especificado.
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
Grasp the SD board cable connector with a pair of tweezers and pull it straight away from its socket on the SD board.
2 outras pessoas concluíram este guia.
