Ir para o conteúdo principal
iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32 iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement, Hard Drive: passo 1, imagem 3 %32
    • Before disconnecting the thermal sensor cable, take note of its orientation. It is extremely important to reinstall the connector in the current orientation so the fans will not run at full speed. If you have multiple pins on your replacement hard drive, put the connector closest to the SATA connections and closest to the PCB board.
    • Disconnect the thermal sensor, SATA power, and SATA data cables by pulling their connectors away from the sockets on the hard drive.
  2. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the two T10 Torx screws securing the upper hard drive bracket to the outer case.
  3. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: passo 3, imagem 1 %32 iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: passo 3, imagem 2 %32
    • Slightly rotate the hard drive away from the outer case.
    • Lift the hard drive off its two lower positioning pins and remove it from the outer case.
  4. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the two T8 Torx screws securing the upper bracket to the hard drive.
    • Remove the upper bracket from the hard drive.
  5. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the two T8 Torx pins from the other side of the hard drive.
  6. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: passo 6, imagem 1 %32
    • Carefully peel off the piece of EMI foam attached to the front of the hard drive.
    • Don't forget to transfer this to your new hard drive.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 871
