Introdução
Use this guide to replace a faulty Bluetooth Board.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Disconnect the Bluetooth cable by pulling its connector away from the socket on the Bluetooth board.
9 outras pessoas executaram este guia.
