Introdução
Remove your front bezel to gain access to your iMac's internals.
Ferramentas
Peças
Nenhum componente especificado.
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw PH#2 in the center of the access door.
Remove the access door from your iMac.
The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
Stick two suction cups to opposing corners of the glass panel. Small suction cups used to stick things to windows or shower walls work.
Remove the following 12 screws securing the front bezel to the rear case:
bottom centre two are long (26mm)
four on sides (two left, two right) are medium (18mm)
and the remaining six (four top, two bottom corners) are short (14mm).
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
11 outras pessoas concluíram este guia.
2 comentários
Mystery: I have removed and replaced my bezel many times - most recently to repair the vid card. However this time while powering up fine before replacing the bezel - now, once bezel is in place it won’t power on - but I hear a ‘click’ in the lower right corner after pushing the power. But then, if I pull the bezel back about an inch from the top - it starts >Something seems to be ‘shorting’ ?
