Ir para o conteúdo principal
iMac Intel 24" EMC 2267 CPU Replacement
O que você precisa
  1. iMac Intel 24" EMC 2267 CPU Replacement, Access Door: passo 1, imagem 1 %32
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2267 CPU Replacement, Glass Panel: passo 2, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement, Glass Panel: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  3. iMac Intel 24" EMC 2267 CPU Replacement: passo 3, imagem 1 %32
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
    • When replacing the glass, be sure there's nothing between the glass and the frame. Stray cables could be damaged or crack the glass.
  4. iMac Intel 24" EMC 2267 CPU Replacement, Front Bezel: passo 4, imagem 1 %32
    • Remove the following 12 screws securing the front bezel to the rear case:
    • Eight 13 mm T8 Torx.
    • Four 25 mm T8 Torx.
    • On the 24" iMac Intel Model A1225, the bottom center two screws are long (26mm), four on sides (two left, two right) are medium (18mm), and the remaining 6 (four top, two bottom corners) are short (14mm).
  5. iMac Intel 24" EMC 2267 CPU Replacement: passo 5, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement: passo 5, imagem 2 %32
    • The front bezel is still attached to the iMac by the microphone cable.
    • Gently lift the front bezel from its top edge off the rear case.
    • Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
    • Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
    • When reinstalling the front bezel, start at the lower edge and make sure it is flush with the rear case before lowering the top edge onto the iMac.
  6. iMac Intel 24" EMC 2267 CPU Replacement: passo 6, imagem 1 %32
    • Disconnect the microphone cable connector, removing tape as necessary.
    • For the front bezel to sit properly, be sure to tuck the microphone cable and connector into the void next to the camera board.
  7. iMac Intel 24" EMC 2267 CPU Replacement, Display Panel: passo 7, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement, Display Panel: passo 7, imagem 2 %32 iMac Intel 24" EMC 2267 CPU Replacement, Display Panel: passo 7, imagem 3 %32
    • Remove the two 5.3 mm T6 torx screws from the LCD connector.
    • Firmly grasp the pull tab on top of the connector and pull it straight up out of its port.
    • Make sure that you are pulling the tab and not the connector cable.
  8. iMac Intel 24" EMC 2267 CPU Replacement: passo 8, imagem 1 %32
    • Remove the eight T8 Torx screws securing the display panel to the rear case.
    • The iMac shown is a 20" model, but the screw locations should be approximately correct.
  9. iMac Intel 24" EMC 2267 CPU Replacement: passo 9, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement: passo 9, imagem 2 %32 iMac Intel 24" EMC 2267 CPU Replacement: passo 9, imagem 3 %32
    • Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside.
    • Do not try to remove the display panel completely as it is still connected to the rest of the device.
    • While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
  10. iMac Intel 24" EMC 2267 CPU Replacement: passo 10, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement: passo 10, imagem 2 %32
    • While still holding the display panel up, use two fingers to firmly push down on the power supply cable connector from its socket.
    • Be very careful not to touch the exposed face of the power supply to avoid electric shock from the many large capacitors attached to the other side of the board.
  11. iMac Intel 24" EMC 2267 CPU Replacement: passo 11, imagem 1 %32
    • Lift and remove the display panel from the device.
  12. iMac Intel 24" EMC 2267 CPU Replacement, Logic board teardown: passo 12, imagem 1 %32
  13. iMac Intel 24" EMC 2267 CPU Replacement, Unplug temperature sensor: passo 13, imagem 1 %32
    • Remove the warranty stickers.
    • Unplug the CPU temp sensor.
  14. iMac Intel 24" EMC 2267 CPU Replacement, Heat sink disassembly: passo 14, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement, Heat sink disassembly: passo 14, imagem 2 %32
    • Remove the four Philips #2 screws.
    • Flip over the logic board.
    • Unscrew and remove the four Torx 8 screws.
  15. iMac Intel 24" EMC 2267 CPU Replacement, Heat sink cleanup: passo 15, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement, Heat sink cleanup: passo 15, imagem 2 %32
    • Wipe the thermal paste with with a microfibre cloth wetted with an alcoholic solution.
    • Keep away from any electronic parts during the cleanup step.
  16. iMac Intel 24" EMC 2267 CPU Replacement, CPU disassembly: passo 16, imagem 1 %32
    • Rotate the locking screw by half a turn (counterclockwise).
    • The locking mount should slightly move backward.
    • Gently remove the old CPU lifting it up vertically.
  17. iMac Intel 24" EMC 2267 CPU Replacement, New CPU installation: passo 17, imagem 1 %32 iMac Intel 24" EMC 2267 CPU Replacement, New CPU installation: passo 17, imagem 2 %32
    • Align the socket and the new CPU with the help of the trimmed corner.
    • Gently drop the CPU in its socket.
    • Don't use any force here, it should fit easily in its socket.
    • Lock the CPU by rotating the locking screw half a turn clockwise.
    • Drop a little bit of thermal paste on the center of the CPU.
    • When reassembling the heat sink, gently squeeze it to spread the thermal paste.
Conclusão
To reassemble your device, follow the instructions in reverse order.
7 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Bastien Arata
Membro desde: 06/29/16
485 Reputação
Autoria de 1 guia
1Comentário do guia
Anyone have any tips or advice as to what CPUs would work best?
May Goodman - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 42
Últimos 30 dias: 188
Ao todo: 12,475
