Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
Pull the black plastic RAM tab away from your iMac to eject the RAM module.
Grab the RAM module by its edges and pull it straight out of its slot.
53 outras pessoas executaram este guia.
5 comentários
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
