Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Disconnect the LCD temperature sensor by pulling the connector straight out of its socket on the logic board.
Remove the two 5.3 mm T6 Torx screws securing the display data cable to the logic board.
Disconnect the display data cable connector from its socket on the logic board by pulling the attached plastic tab towards you and away from the iMac.
Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
Lift the right side of the display panel a few inches up from the iMac.
With the LCD lifted, disconnect the LCD cable by pulling down.
Alternatively, the LCD power cable can be disconnected from the LCD, rather than the power supply.
Continue to lift the LCD from the right side.
Remove the LCD.
4 outras pessoas executaram este guia.
