Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to upgrade the two RAM sticks in your iMac for an instant increase in speed.
O que você precisa
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
20 outras pessoas executaram este guia.
3 comentários
Hi, i'd love to make some upgrades but can't remember which imac 24is mine. Where can I read it? Can I switching it on? Thanks
hello, i already have 2GB, is it possible to add more? thank you!
via Everymac.com
Standard RAM: 1 GB Maximum RAM: 4 GB*
Details: 1 GB of RAM is installed as two 512 MB SO-DIMM modules.
*Apple officially supports 3 GB of RAM, but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules
