Ir para o conteúdo principal
iMac Intel 24" EMC 2111 RAM Replacement
O que você precisa
  1. iMac Intel 24" EMC 2111 RAM Replacement, Access Door: passo 1, imagem 1 %32 iMac Intel 24" EMC 2111 RAM Replacement, Access Door: passo 1, imagem 2 %32
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 RAM Replacement, RAM: passo 2, imagem 1 %32
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  3. iMac Intel 24" EMC 2111 RAM Replacement: passo 3, imagem 1 %32
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
Conclusão
20 outras pessoas executaram este guia.
3 comentários
Hi, i'd love to make some upgrades but can't remember which imac 24is mine. Where can I read it? Can I switching it on? Thanks
Fabrizio Lazzeretti - Responder
hello, i already have 2GB, is it possible to add more? thank you!
connie dekker - Responder
via Everymac.com
Standard RAM: 1 GB Maximum RAM: 4 GB*
Details: 1 GB of RAM is installed as two 512 MB SO-DIMM modules.
*Apple officially supports 3 GB of RAM, but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules
emaginechild -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 16,319
