Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
Peel the two highlighted EMI shield tabs off the frame of the LCD.
Remove the two T6 Torx screws securing the display data cable to the logic board.
Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
De-route the inverter cable from its location next to the CPU fan.
Remove the eight T8 Torx screws securing the display assembly to the rear case.
Peel the strip of foam tape off the top edge of the CPU/GPU heat sink framework.
Remove the following four screws:
Two 18 mm T10 Torx coarse thread screws
Two 14.3 mm T10 Torx fine thread screws
Rotate the power supply out of the rear case from its left side.
Disconnect the DC-Out cable by depressing the lock on the connector while pulling it away from its socket on the power supply.
Disconnect the AC-In cable by disconnecting its lock while separating the two halves of its connector.
Remove the power supply from the iMac.
46 outras pessoas executaram este guia.
4 comentários
I didn't do steps 8-10 and it still worked great.
The guide does not state you need a T6 until you get to the part where you need to remove the display. Please fix that.
Went pretty well… replaced the power supply and it started up on the first try after being idle for 5 years
