Ir para o conteúdo principal
iMac Intel 24" EMC 2111 PRAM Battery Replacement
O que você precisa
  1. iMac Intel 24" EMC 2111 PRAM Battery Replacement, Access Door: passo 1, imagem 1 %32 iMac Intel 24" EMC 2111 PRAM Battery Replacement, Access Door: passo 1, imagem 2 %32
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 PRAM Battery Replacement, Front Bezel: passo 2, imagem 1 %32
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
    My iMac had four 6mm T8 Torx screws (so not one 8mm screw)
    floor - Responder
    My late 2006 iMac24 also has only 4, 6mm long T8 screws here.
    JC Gidley - Responder
  3. iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 3, imagem 1 %32 iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 3, imagem 2 %32
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
    My iMac did not have the "small bridge of material" mentioned, however the bezel just lifted off easily.
    maccentric - Responder
  4. iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 4, imagem 1 %32 iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 4, imagem 2 %32 iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 4, imagem 3 %32
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  5. iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 5, imagem 1 %32
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  6. iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 6, imagem 1 %32 iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 6, imagem 2 %32 iMac Intel 24" EMC 2111 PRAM Battery Replacement: passo 6, imagem 3 %32
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
    I found it easier not to remove the cables connecting camera and microphone, but rather to lean the plastic frame agains a pile of books so that it could rest almost vertical avoiding the need to disconnect those two sensitive cables.
    Stefano C - Responder
    I agree that for a simple, quick battery change, don't risk damaging those delicate wires. Ignore Step 6 and instead of disconnecting the mic and camera wires, keep them in place and just have a friend hold the plastic frame up while you change the battery, or prop it up as mentioned by Stefano C above.
    WT Kwok - Responder
    Make sure you double check the new logic board for the presence of the GPU assembly before installing. I stupidly installed a new board without moving the GPU from the old one first. So i guess you can say this guide worked for me twice. :)
    Trevor Kearsey - Responder
  7. iMac Intel 24" EMC 2111 PRAM Battery Replacement, PRAM Battery: passo 7, imagem 1 %32 iMac Intel 24" EMC 2111 PRAM Battery Replacement, PRAM Battery: passo 7, imagem 2 %32
    • Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
    • Remove the PRAM battery.
    • Be sure to replace the battery with a new CR2032 Lithium battery cell.
Conclusão
6 outras pessoas executaram este guia.
Um comentário
what should i do if the mac cant switch on or no light afther changing the pram battery?
Rudy Nurdin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 25,452
