Introdução
Use this guide to replace the CPU.
O que você precisa
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
My iMac did not have the "small bridge of material" mentioned, however the bezel just lifted off easily.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
I agree that for a simple, quick battery change, don't risk damaging those delicate wires. Ignore Step 6 and instead of disconnecting the mic and camera wires, keep them in place and just have a friend hold the plastic frame up while you change the battery, or prop it up as mentioned by Stefano C above.
Make sure you double check the new logic board for the presence of the GPU assembly before installing. I stupidly installed a new board without moving the GPU from the old one first. So i guess you can say this guide worked for me twice. :)
Remove the two T6 Torx screws securing the display data cable to the logic board.
Wait, we need a T6 screwdriver as well?
I purchased the T8 and T10 from your site as per the parts list above and now am here with an opened iMac on the dining room table unable to continue :/
Remove the eight T8 Torx screws securing the display assembly to the rear case.
It would be useful to use a torx screw driver with a long, narrow shank… some of these screws are in tight places.
It may also be useful to prop up the back so it is level. This will prevent the screws from falling inside. They can be retrieved once the scene is off.
Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
Peel the tape away from the lower corner of the right speaker.
Use the flat end of a spudger to pry both antenna connectors off their sockets on the AirPort card.
Use the tip of a spudger to push the CPU thermal sensor cable connector out of its socket on the logic board.
Use a small flathead screwdriver to rotate the CPU lock 180 degrees counter-clockwise.
Lift the CPU straight up from its socket.
I am here , could I put on it the x7900 2,8ghz cpu? I understand that if the cpu is an odd number , you could use another odd number of cpu like this , If not , you could use the T7600 as last cpu that works .
I'm right ??? the imac have a white light , no sound . no screen logo . I don't know if i could make work this x7900 on it ?????
6 outras pessoas executaram este guia.
Um comentário
Just finished this refurb…. fantastic site and great guide.
The GPU was overheating, and initially, I used SMFan to increase minimum fan speeds and disabled the GPU by following this video
https://www.youtube.com/watch?v=1GDSolVl...
but obviously this limited performance, so I thought , maybe refreshing the thermal paste was help and it has - I decided to do the CPU and the GPU at the same time and the only issue was the antenna terminals broke on the Bluetooth board as I remove the cable - being a bit heavy handed.
A Bluetooth dongle later and this is all fine, the system still runs a little hot, but that’s to be expected and for a 13 year old Mac, its pretty good.
Thanks Folks - really wonderful.
