Pular para o conteúdo principal
Introdução
Use this guide to replace a broken ambient temperature sensor.
  1. Loosen the two Phillips screws securing the access door to your iMac. Both screws remain captive within the access door.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. Remove the following screws along the lower edge of your iMac:
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
  3. Lay your iMac stand-side down on a flat surface. To lift the front bezel off the iMac, simultaneously:
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  4. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge. The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case. Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  6. If necessary, remove the strip of tape covering the microphone cable connector.
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  7. Disconnect the microphone cable. Disconnect the camera cable by pulling its connector away from the socket on the camera board. The camera cable connector and socket are delicate and easily bent. Remove with caution.
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  8. Pull the ambient temperature sensor cable out of its socket on the logic board.
    • Pull the ambient temperature sensor cable out of its socket on the logic board.
  9. Use the flat end of a spudger to pry the ambient temperature sensor off the left speaker body.
    • Use the flat end of a spudger to pry the ambient temperature sensor off the left speaker body.
    • Remove the ambient temperature sensor and its cable from the iMac.
Conclusão
Uma outra pessoa concluiu este guia.
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Todo: 4,553
