Introdução
Follow the steps in this guide to replace the FaceTime HD camera in a 21.5" Retina 4K Late 2015 iMac.
Ferramentas
Peças
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Hold the display with one hand while using your other hand to unplug the display power cable.
Use the tip of a spudger to flip down the metal retaining bracket on the camera cable.
Remove the two 4.3 mm T5 Torx screws securing the camera board to the top of the rear enclosure.
Uma outra pessoa concluiu este guia.
