Introdução
Follow the steps in this guide to upgrade or replace the SATA hard drive in a 21.5" Retina 4K 2019 iMac. Note that if you are upgrading your drive, you will need to clone your existing hard drive onto the replacement prior to performing this upgrade to keep your files and operating system.
Some images in this guide use an older iMac, which has minor visual differences. These differences do not affect the repair procedure.
O que você precisa
With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
Run the tool up along the left side of the display.
Hold the display with one hand while using your other hand to unplug the display power cable.
Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
Two 21 mm screws
One 9 mm screw
One 27 mm screw
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
Peel the rubber bumper off one side of the hard drive.
Repeat for the other side.
27 outras pessoas executaram este guia.
15 comentários
Great guide! I had a failing fusion drive and upgraded to an SSD and got the 64gb RAM maxxer kit while I was in there. everything went really smoothly and my computer is so much faster. My only mistake was that I didn’t clone the HDD before taking the imac apart. I had to put it all back together with the old drive, clone to the SSD, take it all apart again, replace the SSD, put it back together to verify that it was even gonna work, then take it all apart again to finish up the RAM upgrade. But… it’s all good. Thanks for the great guide!
You cannot replace a conventional “Hard drive” in this model iMac.
DO NOT attempt this upgrade until you understand two important facts:
1) The drive in your iMac MUST BE a ‘SSD’ or a ‘Fusion drive’. If it is a conventional HDD, stop. There is NO PCIe CONNECTOR inside to connect a new blade drive.
2) Click on the link in this iFixit for "clone your existing hard drive". All the more recent Apple CPU's are now classified as 'T2 secure chips'. Cloning is no longer straightforward, e.g. "Hold down Opt key during restart, etc." You have to bypass/disable certain security features on your iMac, and this is somewhat of a lengthy process. If you do not, when you try to boot from an external drive you will see nothing but a black screen.
Excellent step by step guide, thank you. I will definitely refer to this when I upgrade my 250G SSD which, BTW, is WAY too small. There's only 100G left, and only apps are Logic Pro X, Numbers/Keynote/Pages, iTunes & a few utilities... hardly any actual work
Thanks for the information given. One follow-up question having a SSD-only 2019 iMac: Is the 2.5" harddrive enclosure and Sata-Cable included in this one? I would like to a) upgrade the PCIe-SSD but also put in a slightly bigger 2.5" SSD in place of the - currently non-existent - harddrive. Knowing Apple I am pretty sure that they did not include the Harddrive enclosure in SSD-only 2019 iMacs - plus using proprietary Sata connectors probably >.<
The guide here mentions nothing of upgrading a blade ssd. If I open my imac and see a HDD can't I just swap it with a 2.5'SSD?
Your message is not clear. This guide is for a conventional drive upgrade for a Pre T2 2019 iMac.
This guide is also for an iMac that is Pre-T2, so your second point is not relevant either.
Sure, do not follow this guide if you wish to upgrade your SSD equiped iMac, or a 2020 iMac or iMac Pro.
