Ir para o conteúdo principal
iMac Intel 21.5" EMC 3068 Display Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: passo 1, imagem 1 %32 iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: passo 1, imagem 2 %32
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  2. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 2, imagem 1 %32 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 2, imagem 2 %32 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 2, imagem 3 %32
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  3. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 3, imagem 1 %32 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 3, imagem 2 %32 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 3, imagem 3 %32
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Conclusão
Adam O'Camb
Membro desde: 04/11/15
181.064 Reputação
416 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 66
