Introdução
Use this guide to replace the left speaker.
Peças
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Use a pair of tweezers to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Use the tip of a spudger to push the fan cable connector out of its socket on the logic board.
Use the tip of a spudger to walk the left speaker cable connector out of its socket.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
