Introdução
Use this guide to replace the AirPort/Bluetooth card.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Use a pair of tweezers to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
Quase terminado!
To reassemble your device, follow these instructions in reverse.
Conclusão
