Introdução
Use this guide to replace the right speaker.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
Pull the connector downwards to remove it from its socket.
Quase terminado!
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
Conclusão
