Ir para o conteúdo principal
Introdução
Internal Prerequisite. Pulling out logic board to access SSD power and data connectors.
Peças
Nenhum componente especificado.
  1. In the proceeding steps, you will disconnect the following cables:
    • In the proceeding steps, you will disconnect the following cables:
    • SD Board
    • Left/Right Speaker and Microphone
    • Audio Port
    • Wi-Fi Antenna
    • Right Temperature Sensor, Bluetooth/Ambient Light Sensor/Camera/Left Temperature, and Hard Drive Fan
    • CPU Fan/Ambient Temperature and Power Button
    • IR Sensor
  2. Pull the SD board cable out of its socket on the logic board.
    • Pull the SD board cable out of its socket on the logic board.
  3. Disconnect the microphone, left speaker, and right speaker cables by pulling their connectors toward the right side of the iMac. Disconnect the microphone, left speaker, and right speaker cables by pulling their connectors toward the right side of the iMac. Disconnect the microphone, left speaker, and right speaker cables by pulling their connectors toward the right side of the iMac.
    • Disconnect the microphone, left speaker, and right speaker cables by pulling their connectors toward the right side of the iMac.
  4. Use the flat end of a spudger to pry all three AirPort antenna connectors up from their sockets on the AirPort board. During reinstallation, connect the cable with no stripes to the socket marked CH0, the cable with one stripe to CH1, and the cable with two stripes to CH2.
    • Use the flat end of a spudger to pry all three AirPort antenna connectors up from their sockets on the AirPort board.
    • During reinstallation, connect the cable with no stripes to the socket marked CH0, the cable with one stripe to CH1, and the cable with two stripes to CH2.
  5. Pull the hard drive fan connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
    • Pull the hard drive fan connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
  6. Use your thumbnails on both sides of the Bluetooth/ambient light sensor/camera/left temperature connector to push it toward the top edge of the iMac and out of its socket on the logic board.
    • Use your thumbnails on both sides of the Bluetooth/ambient light sensor/camera/left temperature connector to push it toward the top edge of the iMac and out of its socket on the logic board.
  7. Use your thumbnails to push the right temperature sensor connector toward the top edge of the iMac and out of its socket.
    • Use your thumbnails to push the right temperature sensor connector toward the top edge of the iMac and out of its socket.
  8. Pull the CPU fan/ambient temperature sensor connector toward the bottom left edge of the iMac and out of its socket on the logic board.
    • Pull the CPU fan/ambient temperature sensor connector toward the bottom left edge of the iMac and out of its socket on the logic board.
  9. Pull the power button connector toward the bottom left corner of the iMac to disconnect it from its socket on the logic board.
    • Pull the power button connector toward the bottom left corner of the iMac to disconnect it from its socket on the logic board.
  10. Use your thumbs to push the IR sensor connector toward the top edge of the iMac and out of its socket on the logic board. Pull the IR sensor board up from behind the front face of the outer case.
    • Use your thumbs to push the IR sensor connector toward the top edge of the iMac and out of its socket on the logic board.
    • Pull the IR sensor board up from behind the front face of the outer case.
    • Remove the IR sensor and set it aside.
  11. Pull the audio port cable connector toward the left side of the iMac to disconnect it from the logic board. Do not pull the cable toward yourself (away from the front face of the logic board) as you disconnect it.
    • Pull the audio port cable connector toward the left side of the iMac to disconnect it from the logic board.
    • Do not pull the cable toward yourself (away from the front face of the logic board) as you disconnect it.
    • Peel the audio port cable off the front face of the logic board and let it hang down as shown in the second picture.
  12. Remove the following seven screws:
    • Remove the following seven screws:
    • Two 7 mm T10 torx screws
    • One 30 mm T10 Torx screw
    • Two 25 mm T10 Torx screws
    • Two 21 mm T10 Torx screws
  13. Remove the following four screws from the power supply: One 9.3 mm T10 coarse-threaded screw
    • Remove the following four screws from the power supply:
    • One 9.3 mm T10 coarse-threaded screw
    • One 25 mm T10 coarse-threaded screw
    • Two 22 mm fine-threaded screws
    • Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
  14. Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac. Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
    • Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
    • Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
    • Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
  15. Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
    • Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
    • Remove the power supply from the outer case.
  16. Remove the plastic wall that is installed directly to the right of the LED driver board.
    • Remove the plastic wall that is installed directly to the right of the LED driver board.
  17. Slightly pull the logic board away from the back of the outer case, then lift it upward to clear the lower front face of the outer case. Slightly pull the logic board away from the back of the outer case, then lift it upward to clear the lower front face of the outer case.
    • Slightly pull the logic board away from the back of the outer case, then lift it upward to clear the lower front face of the outer case.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,129
