Introdução
Prereq only.
O que você precisa
Remove the two 9 mm T10 Torx screws securing the upper hard drive bracket to the outer case.
Slightly rotate the hard drive out of the outer case and lift it up off its mounting pins toward the top edge of the iMac.
Mine seems to still be connected by something else on the other side, and I cannot remove it…
Disconnect the SATA data cable and SATA power connector from their respective sockets by pulling each connector away from the hard drive.
My iMac HDD have 3 ports in the back, SATA data, SATA power and a small one that looks like jumpers pins. When i removed the HDD there was a cable in it. Does anyone know what it is? I bought a new HDD and this port is slightly different. Thanks in advance.
It is a sensor, it is used by the fan control. I did not connect it because my SSD does not have this extra port. So after the iMac reboot, everything worked but the fan was always on (noisy!). I solved this issue by installing a small soft called ssdfanctrl in order to control the fan manually. All good now.
Mine does not look like this AT ALL
jinnifer douglass - Responder
