Ir para o conteúdo principal
iMac Intel 21.5" EMC 2428 Access Door Replacement
O que você precisa
  1. iMac Intel 21.5" EMC 2428 Access Door Replacement, Access Door: passo 1, imagem 1 %32 iMac Intel 21.5" EMC 2428 Access Door Replacement, Access Door: passo 1, imagem 2 %32
    • Unplug your iMac's AC cord along with any peripheral devices.
    • Lay your iMac face-down on a soft, clean surface as shown.
    • Be sure there isn't any dirt or debris on your work surface, as it may scratch the glass panel on the front of your iMac. We recommend placing a towel between the iMac and the work surface.
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • All three screws will remain captive in the access door.
    • Remove the access door.
Conclusão
12 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 7,660
