Introdução
Use this guide to replace the IR board.
Ferramentas
Peças
Nenhum componente especificado.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
2 outras pessoas concluíram este guia.
