Ir para o conteúdo principal
iMac Intel 21.5" EMC 2308 Optical Drive Replacement
O que você precisa
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  1. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 2, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 2, imagem 2 %32
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  2. iMac Intel 21.5" EMC 2308 Optical Drive Replacement, Display: passo 3, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement, Display: passo 3, imagem 2 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement, Display: passo 3, imagem 3 %32
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  3. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 4, imagem 1 %32
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
  4. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 5, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 5, imagem 2 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 5, imagem 3 %32
    • Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • The vertical sync ribbon cable has a ZIF style end, but the socket has no lock or retaining flap. Simply pull the cable away from its socket toward the optical drive side of the iMac to disconnect it from the LED driver board.
  5. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 6, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 6, imagem 2 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 6, imagem 3 %32
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  6. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 7, imagem 1 %32
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be careful when disconnecting and reconnecting this cable, as it is easily damaged.
  7. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 8, imagem 1 %32
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  8. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 9, imagem 1 %32
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  9. iMac Intel 21.5" EMC 2308 Optical Drive Replacement, Optical Drive: passo 10, imagem 1 %32
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
  10. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 11, imagem 1 %32
    • Remove the four 9 mm T10 Torx screws securing the optical drive to the outer case.
  11. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 12, imagem 1 %32
    • Lift the inner edge of the optical drive and maneuver its connector past the frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the edge of the outer case to gain clearance for disconnecting the optical drive cable.
  12. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 13, imagem 1 %32
    • Use the flat end of a spudger to help disconnect the optical drive cable.
  13. iMac Intel 21.5" EMC 2308 Optical Drive Replacement, Optical Drive: passo 14, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement, Optical Drive: passo 14, imagem 2 %32
    • It is not necessary to peel all of the EMI tape off the optical drive bracket. Only peel up the portion highlighted in red that is attached to the body of the optical drive.
    • Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
  14. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 15, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 15, imagem 2 %32
    • Remove the two T10 Torx screws from both sides of the optical drive (four screws total).
  15. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 16, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 16, imagem 2 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 16, imagem 3 %32
    • If necessary, use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
  16. iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 17, imagem 1 %32 iMac Intel 21.5" EMC 2308 Optical Drive Replacement: passo 17, imagem 2 %32
    • Use the tip of a spudger to peel back the piece of foam tape covering the optical drive thermal sensor.
    • Use the flat end of a spudger to carefully pry the thermal sensor up off the adhesive securing it to the optical drive.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
Conclusão
26 outras pessoas executaram este guia.
3 comentários
A word of caution when reassembling. Be sure to replace the LCD thermal sensor connector and the optical drive thermal sensor connector with the contacts facing down. They are both very small and easy to overlook the contact points. If either or both are reinstalled wrong the iMac will not power up. You will get a white screen momentarily and then it will go black. I made that mistake and had to go back in and correctly insert them which solved the power up problem.
cwrd - Responder
I successfully put an SSD (mounted in OWC data doubler) into the optical drive slot.
I got slightly thrown for a moment that at step 10, the iMac was apparently rotated 180 degrees. I didn't really want to change my work position, so I turned my iPad upside down to follow the pictures correctly. Not sure why the perspective changed at that point in the manual.
The other "interesting" task was reattaching the LCD, what with the nearby rare earth magnets trying to steal the screws. Having a heavily magnetized torx screwdriver was a big help; I just took a magnet of my own and stuck it on the handle end of the shaft, and then it held the screw enough to make the job possible.
I was quite relieved when my iMac booted after all this. :)
neilweinstock - Responder
Per error se'm va introduir una targeta portadora de microSD tipus SD a traves de la ranura del lector de CD-DVD.
Seguint aquesta guia perfectament bé explicada i amb les eines adequades, T10 Torx, tornavís de rellotger tipus estrella o philips i en el meu cas dues ventoses solidaries tipus mànec d'enganxar a la paret de la dutxa per no caure; he aconseguit recuperar la microSD, el lector de CD-DVD i el iMAC continua sencer.
Mil gràcies Andrew Bookholt, ets un crack e indubtablement molt bona persona.
atvillarroya - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 71
Duração total: 70,225
