Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace a broken LED driver board.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the two 9 mm T10 Torx screws securing the LED driver board to the outer case.
6 comentários
Same question as above, how to check if it's power board or LED driver board that is damaged?
It might not be a complete answer but I had to change my LED Driver Board when my display went black ( as if the computer was in sleep mode ) as soon as the computer was on. I had to push the power button to get the screen back multiple time. There was also a problem with the graphic card but even after changing the GC, the screen would go black. We figure it was the LED Driver Board when we realized the computer wouldn’t show anything on an external monitor. Hope it helps :)
I have the same problem Mary. The imac starts but no screen and i need to shut down/turn on a few times until i see the normal screen. Very ocassionally the screen blinks too or turns to black and i can only see stuff by flashing a light to the LCD. Where did you buy the LED Driver Board?? Can’t find it anywhere..
