Introdução
Use this guide to replace a broken Bluetooth board.
Ferramentas
Peças
Nenhum componente especificado.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
Uma outra pessoa concluiu este guia.
Um comentário
Seriously this is so incomplete! What about the cable that connects the Bluetooth to the logic board!?!??? Like this is so half way explanatory!
