Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95-
Stick two suction cups to opposing corners of the glass panel.
Gently pull the glass panel straight up off the iMac.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Disconnect the microphone cable connector, removing tape as necessary.
Disconnect the IR sensor cable from the IR board by pulling its connector away from the socket on the IR board.
If necessary, use a spudger to pry up the left edge of the black tape covering the IR sensor to reveal the screw hidden underneath.
Remove the two T6 Torx screws securing the IR board to the logic board.
