Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95-
Stick two suction cups to opposing corners of the glass panel.
Gently pull the glass panel straight up off the iMac.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Disconnect the microphone cable connector, removing tape as necessary.
Use the flat end of a spudger to pry both antenna connectors up off the AirPort Extreme card.
Remove the single T6 Torx screw securing the AirPort Extreme card to the logic board.
Pull the AirPort Extreme card straight away from its socket.
