Introdução
Remove your access door to replace RAM chips or to open the case of your iMac.
O que você precisa
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
10 outras pessoas executaram este guia.
The grid won't fall off by itself. You'll have to help it. Use the smallest screwdriver you have; the Torx 6 worked fine for me. It should enter in one of the many holes composing the grid. Use it as a lever to ploy the grid a little bit. You may catch it with your fingers and that's it.
Be carefull not to damage the hole by a too strong leverage.
Laurent - Responder
much more safer to use duct tape, instead of torx 6. (glue it along the length of the grid and pull). it will loose instantly and smooth;)
Hofmann78rus - Responder
Anyone know a guide to replace the plastic piece this screw connects to? I accidentally forgot this step - went to remove the front bezel and bent the plastic piece the access door connects to.
Jason Augustin - Responder
