Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
Disconnect the hard drive thermal sensor by pulling its connector toward the top of your iMac.
Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself.
Rotate the hard drive toward yourself, then lift it up off its mounting pins.
Insert the flat end of a spudger between the SATA power cable connector and the edge of the hard drive.
Twist the spudger to separate the connector from the hard drive.
Pull the SATA power connector away from the hard drive.
Disconnect the SATA data cable by pulling its connector away from the hard drive.
4 outras pessoas executaram este guia.
Um comentário
Walter, I was working on a mid-2007 IMac (2133) and found your instructions helpful but not always complete or right. I have added some comments in some of the steps to clarify.
