Introdução
Remove the glass panel to gain access to your iMac's internals.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
43 outras pessoas executaram este guia.
Um comentário
Good Instructions: Warning!, make sure all the screws are fully seated down prior to glass install. This is what happens when you don't:
