Ir para o conteúdo principal
iMac Intel 20" EMC 2133 and 2210 Access Door Replacement
O que você precisa
  1. iMac Intel 20" EMC 2133 and 2210 Access Door Replacement, Access Door: passo 1, imagem 1 %32
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
    isn't it actually pc2-5300s ?
    grze - Responder
    It is for the 2133, the 2210 uses 6400
    maccentric - Responder
    There are comments elsewhere in this step by step re. the bezel removal. That step does NOT show how to remove it. Well, take the 5:39 secs to watch the above video. It clearly shows how the aluminum framed bezel easily comes off once you've seen it done. To whoever decided to preface these instructions with that video, thank you.
    ECJohansen - Responder
Conclusão
36 outras pessoas executaram este guia.
2 comentários
Situs Tuandomino adalah agen poker online yang sangat di percayai memberikan tingkat kemenangan yang begitu tinggi dalam memenangkan permainan Game online di Indonesia
tuansakong99 - Responder
Spam isn't cool.
Jason Zak -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 25
Duração total: 22,449
