Ir para o conteúdo principal
iMac Intel 17" Access Door Replacement
O que você precisa
  1. iMac Intel 17" Access Door Replacement, Access Door: passo 1, imagem 1 %32 iMac Intel 17" Access Door Replacement, Access Door: passo 1, imagem 2 %32
    • Loosen the two captive Phillips screws securing the access door to the iMac.
    • Remove the access door from the iMac.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
    That is a really, really unnecessarily complex way of fitting a new hard drive. Thanks, but no thanks...
    annax - Responder
    Citação de annax:
    annax, if you can suggest a simpler way we're all ears!
    Jake Simmonds - Responder
    I found this guide to be very useful. The installation was super easy, especially since I've never opened my iMac before. I was able to skip steps 6, 7, 9, 10 and 14. Wish I had one of those long skinny magnetic torx screwdriver's though. I had to use duct tape to hold the screws on the end of the bit for step 12.
    I used this opportunity to vacuum out the dust with mini attachments. Much needed after 3 years ;0)
    Awesome site!!! Thanks for sharing your knowledge and saving me time and $$$!
    Eric Patten - Responder
    Yes I did it! thanks for this very good manual
    Philippe d Anfray - Responder
Conclusão
6 outras pessoas executaram este guia.
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 7,244
