Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Trip over your power cord? Use this guide to replace your AC power inlet.
O que você precisa
Loosen the two captive Phillips screws securing the access door to the iMac.
Remove the access door from the iMac.
Flip your iMac over and lay it stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the Front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Remove the 30 mm T10 Torx screw securing the left speaker to the rear case.
Pull the power button cable connector up off its socket on the logic board.
Pull the optical drive fan off the posts protruding from the rear case and lift it out of rear case, de-routing cables as necessary.
Use a pair of tweezers to pull the AC-in cable out from underneath the chassis.
4 outras pessoas executaram este guia.
